Chevy/GMC Trucks \  1992 gmc suburban front end help
views 248
replies 5
following 6
dropedburban   +1y
ok heres my problem i have a 1992 gmc suburban and i would like to use a grill chrome grill from a 1994- 1999 chevy suburban i would like to know if it will fit my truck and if not what can i do to make it fit heres a link of the grille i would like to use it comes with a set of headlights and everything also i woild like to know what conversion can i do from another car or truck that would be unique _______________________________________http://cgi.ebay.com/ebaymotors/94-99-SUBURBAN-1PC-GRILLE-CLEAR-HEADLIGHT-BUMPER-CORNER_W0QQitemZ8058591084QQcategoryZ33645QQrdZ1QQcmdZViewItem
kotalaynframe   +1y
it should bolt right up i have done that conversion before on a buddys truck
MMLILJOKER   +1y
i think the core support is differnt dont quoit me on it though
mazberrydelight   +1y
coresupports the same , wiring harnesss might be diffrent but they can be interchanged where they plug in threw the firewall
SHOWTIME   +1y
core support is the same the wiring will be the same as long as the front end you are taking of has the composite 1 pc style of head light if it has the work truck style with the h6054 head light then you will have to change the wiring and the grill will bolt up pretty much straight up there is a couple of holes from the 94 and up grill that will not line up on the older core but no big deal and those ones are in the middle of the grill if i'm not mistaken
bdydrped   +1y
you have to change the bumper brackets and the 3 fillers also. the grilles and fillers stick further forward so you have to move the bumper out.... or you have to trim down your fillers
