bagdb2200
Originally posted by Psycopath
Originally posted by rrusd
I would have sent that bracket back to SD. I realy don't think they are puting a different rear-end in trucks up there. Should be a standard 10 bolt rear-end. I think SD sent you the wrong bracket, probably for an import (seeing as you had metric bolts).
imports dont have those bolts. the threads on the diff were metric, not the kit.so maybe canadian models are different, alot of the hardware on the truck is metric.i just wanted 2 know if anyone had heard of this problem?Bolts on S-10s have been part SAE and part metric for as long as they've been making S-10s. That's just the way they are. Like posted earlier there are 2 different rear ends in S-10's, the 7-5/8 and the 8-1/2". If you had to cut it bigger he probably got one for the 7-5/8 but has a 8-1/2. Is the truck a 4.3 with a 5-spd?
