weird noises comin from the drivetrain
DragDatZu
ight i got a 94 pup and yeserday i oticed it was starting to make weird noises. sounds like some one runnin in a nylon jump suit lol. when i push the clutch in i gets way louder. om times when i drive it just goes away......i think it may be my throw out bearing starting to go bad .....any body have input
farmer joe's avatar
farmer joe
more than likey the T/O bearing. my truck does the same thing, just not bad yet.
BK2LIFE's avatar
BK2LIFE
"sounds like some one runnin in a nylon jump suit..." tell him to get out from under your truck
DragDatZu
i told shim to get the hell out form under there but he wouldnt listen so ima have to get under there and beat his ass lol......ima try and change my clutch and bearings friday and see if that helps any
low_pup
change your pilot bearing while you are at it, only a couple more bucks and your going to kick yourself in the balls if you get it back together and have to change it.
lowtollracer
My Zu-Zu makes a loud whining noise and a friend told me something about the input shaft or maybe the pilot shaft bearings are going out. He said its easy to change, but easy with a lift. I thought it was the rearend,since I have an S-10 rearend. But I changed the fluid and it didn't help. Good luck.
Related Discussions in Isuzu
