accord camber kits
skyler@boman-kemp.com's avatar
accord camber kits
skip1100's avatar
skip1100
where should i go to pick up a camber kit for my 91 accord. its on cylinders, and i love the camber it gets but i hate buying new tires.
shawnswhip's avatar
shawnswhip
jc whittney sport compact catolog has a grip of camber kits from many different brands, and styles...ebay also has a lot to offer. i order mine from jc whittney sport compact.
gravity5's avatar
gravity5
For the front, none of the kits works right...the rear SPC camber kit is good....
As for the front I am in the design process of new front upper arms for a 95 civic right now, fully adjustable, stock balljoint....... but if I can get ahold of some more hondas I might do a couple more styles...
turboh22aakkord
hey man whats going on... when i did my car i just bought a camber kit off ebay ( i dont remember the brand) and it worked fairly well.. when lowered you may even need to grind down the outside of where the upper ball joint sits... cause mine rubbed a little... on the rears all you really need is some grade 8 bolts and some washers thats basickly all that comes with most kits for our accords...
skip1100's avatar
skip1100
i was going to try to fix it with some washers.
turboh22aakkord
yeah, like the camber kit i bought offline the front pice worked well and was a pritty simple assembly it had two difference settings of camber adjustment but it wasnt adjustable which suck and all that came for the back was some grade 8's and some washers... which is a good cheap fix... ( i also ran no camber kit at all with 4" of drop and that chewed up a set of tires in like 2 months.. so i wouldnt advise that haha) good luck man.
