watts link
dropduallie88@hotmail.com's avatar
watts link
dropduallie88's avatar
dropduallie88
does anybody know who sells watts links other than totally polished or kp. I am looking for one preferably with a bearing rather than a bushing.
custommagnums
The TP watts link uses a bearing.
03on22s's avatar
03on22s
Talk to proeuro98 on here. He's making them. I've got one and it's pretty damn beefy. He uses a bushing, but talk to him I bet he'd work with ya.
dropduallie88
tp will not answer the phone and only responded once to an email and it didnt get me anywhere. that is the one I want but I cant get ahold of anybody.
dropduallie88
anybody have any suggestion to what I could use to build my own crank with a bearing? and what to use as a spindle?
BioMax's avatar
BioMax
Aircraft Spruce in Corona, CA sells 4130 by the foot. You can have a machine shop build you a pin. If you can't get ahold of a machine shop call me and I can build you one as well.
I would probably use delrin instead of a bearing tho. I can get you that too or you can call Grainger or McMaster Carr and buy the delrin and have a machine shop make you custom bushings.
bdroppeddak's avatar
bdroppeddak
i have this one i'll sell you, it will work for a frame with about 35" between the framerails right behind the rear end, like s10 or 88-98 chevy, im sure it will fit a slightly wider frame like a mazda too... ive been using a johnny joint for the center pivot, it seems like the ones with just a bushing will get slop quick because theres more than one way it pivots through travel.
bdroppeddak
$150 dollars plus shipping....
V
vinnysmini
The TP watt's link uses 2 S-10 front wheel bearings. Grease them up and you're good to go.
layedexpo22s
you still have that link?
s10
last post by baha +1y
