frontier static drop?
lowfrontier03
does any company make a static drop for the 2003 frontier i am looking to get one but i want to make sure i can drop it without bagging right away
tenfrontier's avatar
tenfrontier
Belltech makes 2" drop spindles. You can put those on and crank your torsion bars down 2" for a 4" drop up front. For the back you can move the leaf spring hanger up about 1.5" and install a 3" block for a total drop of 4.5". You will also need to either remove of trim your bump stops.
lowfrontier03
how do you raise the hanger up i allready have 4 inch blocks
jcjcsoccerkid's avatar
jcjcsoccerkid
its pretty easy..i can send you the diagram later when i get home. i cant do it now cuz photobucket is blocked at my work. its not hard to do at all
pugz's avatar
pugz
the belltech spindles DO NOT WORK with ABS. u must lose your abs to use the spindles. when i put spindles on my 03 we kept all the abs jsut moved the sensors outta the way. the abs light will be on. and abs will not engage but u wont get any adverse affects. i accidentally cut the wires to my abs at one point and my brakes sucked because of it. also shAIM make a dropped lower control arm but they are like 500$ and definatly not worth that much money. if u dont want to do spindles just do a torsion bar drop and some blocks. that will get u an easy and cheap 3/4 drop. then get u some shorter shocks and remove your bumpstops
