what is the good tire size for the rear? I was wanting to run the 255-30-24 but I'm unsure of the weight handling. Any suggestions?
oldskewlkool
24"
lockone
The Toyo 255/30/24s (30.02") handle 1609lbs according to the weight specs on my dealer sheet. Which is plenty if you are not going to tow alot. The only bad part is those Toyo's are on national backorder. I also have a Toyo 275/30/24 (30.6") and a Pirelli 275/25/24 (29.3"). If you are not worried about clearance I usually sale 295/35/24s (32.1") or 305/35/24s (32.4")
jason
Would the 275-30-24 toyos rub together on the rear and if not how much are they?
jason
Oh yeah clearance is a huge issue its body dropped to the rockers I even removed the pinch weld.
lockone
No they wouldnt run together and I will get you a price in the morning. I assume you want 6...
