03 frontier bag question
lowfrontier03
what is involved in bagging the front of an 03 frontier i just bought one and would like to bag it but i just looked under the front and seen that there is no coil springs so what do i have to do
droppedmitsu's avatar
droppedmitsu
need a torsion bracket kit from suicide doors. weld that up in there and also take out the torsion bars
tukin19
or just buy my truck...bagged and bodydropped!
lowfrontier03
thanks and no thanks i dont like buying other peoples work sweet truck though were you at LR this year
tenfrontier's avatar
tenfrontier
You have to cut out the outer part of the crossmember where the bump stop mount is and plate the hole that is left. you have to cut the lower shock mount off of the lca and weld a circle plate onto it(lca). You would then weld in an upper bag plate and gussets onto the outside of the frame. Last but not least, you need to relocate the shocks behind the front suspension. If you are going to run a wheel and tire combo of a 23" overall diameter or more, you will need to install drop spindles to lay out.
