Air Ride Suspensions \  rearend noise
rearend noise
Air Ride Suspensions Q & A
views 76
replies 2
blazer   +1y
I have noise on deacceleration only once in awhile,I've flipped rearend but did not shim it. Was wondering if this is the problem or do I have a bad pinion bearing.truck is 80 chev shortbox half ton.thanks
draggindamax   +1y
wat kinda setup you runnin. i had a truck that the drive shaft was hittin the in put shaft housing of the tranny because the rear end was set up wrong
bdroppeddak   +1y
its the pinion angle, you need to get shims.
