square body chevy
square body chevy
jason
What all do I need to narrow to tuck the all days under my dually? I tried putting them on but it looks like it will need to be about 3 inches narrower in the front and I am not that worried about the back.
lockone's avatar
lockone
3/4 ton spindles/hubs should do the trick...You may have to shorten the control arms also. Depending on if it is bodied or just laying frame lugnut clearance will also be an issue.
dragnasty's avatar
dragnasty
Definate lug nut issues if BD'd. I norrowed my upper and lower control arms 3/4" inch with regular dually hubs and the lugs cleared on my 22"s
jason
this may be hard to picture but the wheels are hitting the fenders at about the middle of the holes. There is no way 3/4 of an inch will clear this I measured about 3 inches to clear the lug studs.
jason
oh yeah its bd'd and the pinch weld has been removed
dragnasty's avatar
dragnasty
I forgot thet I milled an 1/2" off the face of my wheel. So technically my wheels were moved in 1 1/4". I drug mine and rode tucking lugs all the time.
jason
do you think that the offset may be different between a 22 and a 24?
jason
also could a camper speacial have a wider front suspension?
lockone's avatar
lockone
Offsets are the same on 22s and 24s as long as they are both 8.25" wide.
jason
put on some 3/4 ton hubs and now it sits in to damn far. The spindles are supposed to be the same on that body style arent they.
