Off-topic \  Anybody Need a Quad?
Off-topic General Discussions
views 91
replies 0
following 1
BankruptRam   +1y
I went to a Business Aircraft & Jet Preview today and this was there on display.
Specifications and Options
Technical data
engine type 2-cylinder 4-stroke boxer engine
valves 4 valves per cylinder
capacity 1130 cc
power output 95 Horsepower @ 7250 RPM
torque 72 Lb-Ft @ 5500 RPM
catalytic converter controlled 3-way catalytic converter
transmission 6 gears / 1 reverse gear
Mass and weights
tank volume 4.75 Gallons
wet weight 880 Lbs
overall length 87.5 inches
overall width 55 inches
Driving performance
top speed 115-plus MPH
Chassis
frame GG-design-Billet Aluminum
wheel individual wheel suspension with trapezoidal cross-members made of aluminum
suspension struts Four-Wheel Independent A-arm Wishbone Shock Absorber
spring travel 4 inches front and rear
drive Shaft drive to rear differential
brakes hydraulic brake system, 270 mm floating brake disks, 4 wheel- 4 piston GG brake calipers
wheels OZ aluminum cast wheels 16 inch x F; 17 inch x R
tires front: 195/40-16 rear: 225/40-16
Price Base MSRP $49,500.00
Authorized for use in
Germany: Unlimited T
