dssur
you should swap in the whole motor, the pistons on the turbo motor are lower compression which means lower power initially but more room for boost. The intake faces the firewall like Nathan says, you can swap the upper manifold direction like B2200GT did. The exhaust down pipe also will face the front of the truck so you will need a custom one. The distributor will hit the firewall because it is on the rear of the head on an f2t, you will need to cut the firewall to clear. NO you cant use the truck head/distributor, the advance curves are different for turbo/non turbo motors. Physically it will bolt up but you will need to convert the truck to a high pressure fuel system too. A few guys have done it, its not cheap or easy, but it must be fun because they never complain.
