Toyota Trucks \  20s
20s
Toyota Trucks Make Specific
views 301
replies 12
following 9
Yoter   +1y
hellow to all I am new to the site and I have 89 toyota pickup I need to know what offset and rim size I would need to fit 20s on my truck or if i can. I have 2wd fenders and 2inch drop in the front and 3 inch drop in the back thanks in advance
swchhpy   +1y
r u going to bagg or body drop it? i have 20's on mine check it out..
LSCivic   +1y
Run about a 40mm offset and you should be fine with that. I don't beleive the fact that you have the 2wd fenders would be a problem. If you have anymore questions about it, hit up "sadisticiron" on here, his name is Bobby and he knows alot about Toyota's.
Some Drunk Guy   +1y
Dood you can pretty much run what ever 20's you want if your gonna stick with a 2/3 drop....
Yoter   +1y
Well I plan to throw some bags on it and tub it with some 4wd fenders on it so I want to make sure I can tuck in the front. but thank you all for the info I have heard that a 40 to a 37 offset will work in the front but I wanted to know from some guys that have done it so thanks i will post some pics when i get them on
rizz0   +1y
you can run a smaller offset than 40 on a toyota, a 40 will actually put your rim pretty deep into the fender which i personally like cause you can turn better when laid out.
LSCivic   +1y
I have a 40 offset on mine, if you need some pics, just check out my profile!
Some Drunk Guy   +1y
I have a + 35 offset on mine, you can check mine out in my profile...
TacoOn20s   +1y
42 offest, check mine too.
floorrunner   +1y
what wheels are these? they are bada$$Originally posted by swchhpy
