Removing the molding around a chevy Blazer
E
E
ECProductions143
Just wondering if they are stick on or pop clips or somehitng if anyone knows lemme know thanx
E
ECProductions143
ANYONE?????
91 drggn dime's avatar
91 drggn dime
stick on.. and i've tried every method on my s10 from 3m adhesive remover to some other shit, none of it worked worth a flip except a wire brush on a drill.. you might have better luck though.
lownism0
its double sided tape. get an eraser wheel.
slamnscotte's avatar
slamnscotte
its tape. eraser wheel and patentice (pardon my spelling). itll all come off ive done it on more then a couple trucks just dont rush it and youll be fine.
BK2LIFE's avatar
BK2LIFE
yep just did my wifes tahoe lasat weekend. it sucks, its slow, but the eraser is the only thing that works "correctly".. the wire wheel suggestion up above, all i can say is WOW..
laidstude63
also depends on what year i have a 95 and if it has a fake looks like brushed aluminum strip in the middle then it's held on with tape,bolts, and clips and the clips are riveted on GOOD LUCK you'll have drill them out leaving about 8-10 holes per door to fill
LiL bLaZe's avatar
LiL bLaZe
I have saw guys use a heat gun and fising line and it worked pretty well anyone else do this?
N
NYCBlzr9
used wd-40 and a plastic palette knife....but then again i need a paint job too...removed most of it and left minimal scratches.
chillnlikavilln
first off dont use a wire wheel unless...dont use a wire wheel .a heat gun make the molding plyable and lets the tape let go. use a eraser wheel then wipe the residue of with aceatone if you are trying to save the paint.thats the way we do it the body shops
