filler and primer question
E
eargazm
i finished up my license plate box and fixed a few dents in my tailgait sat. and i just noticed i missed a low spot. the whole this is sprayed with trans-star 2k primer the question is can i scuff the primer and put filler over the and then prime it agian or do i need to strip the primer and start over?
foreverlow01's avatar
foreverlow01
scuff it and fill it up
E
eargazm
so i can put filler over the primer thanks bro
jonesn
i would not use regular filler over the primer. there is a product called putty-cote that is finer than regular plastic filler and is made to fix small low spots with out grinding to the metal. if it is a alrge spot thrn i would go ahead an take the primer off with a heave grit. that way you will has the best adheasion
E
eargazm
the low spot is about 4 inches long and aboug 1/8 inch deep i filled the dent but i didnt notice that it carried over.
ricecop425's avatar
ricecop425
i would pound that out unless you want the filler to crack out
bdydrpdblazr
use putty coat not bondo other wise the bondo wont stick to the primer
E
eargazm
so it would be better to go on and strip the primer off and lay new filler over the area
zaccanti's avatar
zaccanti
hey bro if that came back from the paint shop like that i would grind down the area where the dent is at. your already going to have to reprime it, get it to bare metal and either pull it close and mud it or just mud it. either way you gotta prime it so i would go to bare metal to get he best adhesion. then just spot prime wit a few coats and your set. if you want spot prime and block then prime the whole thing again to make it look uniform. just what i would do is all
