Chevy/GMC Trucks \  s-10 fuel cell problems
views 1250
replies 9
following 9
Laydoutbateau98   +1y
i put a fuel cell in the truck and its giving me problems. every now and then its wanting to kill, like its notting gettin gas. changed the filter and all the lines are good. what should i do next?????
LOWLIFE   +1y
Did you leave the internal fuel pump or replace it w/ an external. I replaced mine w/ an external pump from an 89 Ford F-150.
If the lines are good AND you have the return line installed right, only thing I can think of is taking a look at the fuel pump.
projectlayframe93   +1y
if its an electronic internal fuel pump you might wwant to just check the conecctions cuz my 93's leads were loose
lowdyme   +1y
with a s10 your fuel pressure will needs to be around 48 or 50 psi for the engine to run good so if you put a new inline pump then chances are you are not getting enough fuel if thats the case then i suggest you call summit or visit their site summitracing.com better to call tho and tell them your year/make/modle and then they will set you up with what you need
sinwagon   +1y
I ran into the same problem with my old dime. Summit carries a high pressure external fuel pump with a regulator to adjust the pressure. It's been about 10 years so I'm not sure of the part # but one of their techs should be able to help.
Laydoutbateau98   +1y
thanks guys, appreciate the help
bdydrpdblazr   +1y
you need to makle sure that the fuel [pump you are using is putting out the right psi and gpm the motor requires to function properly
vinnysmini   +1y
Also check your grounds...My ground kept shorting out causing my fuel pump to turn off after I installed my fuel cell. G'luck.
bdsonoma   +1y
summit or jegs sells a MSD fuel pump. iv got that on mine, along with a friend of mine. the pump is only 80-85$ both had for over ayear now, no problems. btw 2000 s10 2.2, and my friend has a 2000 with a 4.3.
droptopbenz   +1y
OK number of things. first CHECK FUSES. my blazer didn't run for 2 YEARS because of a 20 amp fucking fuse. ok now all fuses are good. open up fuel cell and look for the return fuel line and if it is returning fuel. if it is . your motor is getting fuel. next your you have 3 lines. a feed and return and a vent. Plug the vent or run that to your tank . thats all the probels and sollutons i have ever had.later
