Mazda Trucks \  Weber problems please help.
Mazda Trucks Make Specific
views 151
replies 4
h2omelon(nick)   +1y
i just got my weber 34DGEC. the problem im having is the throttle cable is too short. What can i do short of getting a new throttle cable? the throttle linkage is on the front and the fuel line is on the rear of the carb.
dssur   +1y
That Weber is a Solex copy, nothing you can do except get a longer cable. The 89-95 toyota truck EFI cable worked for me when I put on my ITB's, it has the same type of attachment on both ends and is about 7 inches longer. If I remember right, you only have to screw down the outside firewall mount to get it to work, I used two self tapping screws and viola! Otherwise it hooked to the mazda pedal and ITB linkage easily. Should work for you too.
h2omelon(nick)   +1y
thanks Russ
h2omelon(nick)   +1y
where do hook the return line to?
Kyrasis6   +1y
If your no longer running the mechanical pump or have a regulator that uses it I would just plug it.
