Mazda Trucks \  Wheels for 4x4 Sheetmetal
Mazda Trucks Make Specific
views 206
replies 4
following 5
frogg   +1y
I keep seeing forums for wheel sizes for 2wd sheetmetal, but i keep missing the ones for the 4wd sheetmetal.Whats the biggest offset you can get? for an example 18x8? 5in or so?and plus how about the 40mm and such?some help would be great..thanks
ShavedMazda   +1y
The wheel size is gonna run pretty much the same with 2wd or 4wd sheet metal ... the 4wd is only giving a inch or two more space at the most so read the forums for 2wd sheetmetal and go off of that info.
rwloper   +1y
From what I understand, the 4wd fenders only give you .750" extra clearance.
detached   +1y
^^^ he is correct its on 3/4"s of an inch of extra space. not much but it works. there is a topic in the mazda section started a few months ago and has a really good section towards the end that russ d posted n it tells the the mininum back space you can run if i remember right
