wht01ranger
did you plug the vacuum lines/ports that you took out? having some of those ports open obviously cause a vacuum leak and will cause rough idle, etc. etc. you obviously can't do anything about the rich part, that's your choice.
so either plug the lines and ports you disconnected or put the stock shit back in. when i first cut my fenders out, i moved everything up, and there is room to move everything up with stock tires, and i doubt your tires are taller than 26inches
