CAN YOU CONVERT 4WD CREW CAB TO 2WD ?
bagged2200
ALRIGHT THIS IS WHAT I HAVE GOING ON I HAVE A 89 SILVERADO AND THE BODY IS PRETTY MUCH JUNK AND THE FRAME IS HACKED UP SO BUT THE MOTOR IS GOOD . ALRIGHT WELL I KNOW SOMEBODY THAT WILL SELL ME A 92 CHEVY CREW CAB 4WD HOW MUCH WORK WOULD IT BE TO CONVERT ALL BY 2WD STUFF OFF OF MY 89 TO THIS 92 4WD? THANKS I THINK IT WOULD BE ALOT COOLER DRAGGIN A 4DOOR ANYWAY THANKS
okcderek's avatar
okcderek
As long as you have all the suspension parts... shouldnt be hard. My buddy had a crew cab and switched to 1/2 ton suspension to run 5 lug wheels.
FluffyFreak's avatar
FluffyFreak
yea man thats cake just unboltin and reboltin man! and since its apart might as well stockfloor it
bdydrped's avatar
bdydrped
the upper control arms and mounts are differnt on 4x4 and 2wd.... and the hubs are different also.... but if you ever plan onrunning semi wheels id hang on to the arms and to make em tuck up in there nice
kboring
The front frame section is different on four wheel drives...you cant just swap over the parts
Dropmaster's avatar
Dropmaster
Anything is possible.
johnz
well if you gonna bd it its simple take all the measurements from your 4wd frame and build a new frame using the front clip of the 2wd
BioMax's avatar
BioMax
I do believe the frames are quite different from 2wd to 4wd in those years. I have built spindles to just what you are asking. If you (me) just built a set of custom dropped spindles to bolt on to the 4wd suspension, it would make your life fairly easy.
mtm's avatar
mtm
take out the front cv shafts... wha-lah 2WD
SHOWTIME
the frames are very differnt it would take a bit of fabrication to change over also your 89 is it a reg cab if it is you have to cut the frame down move the rear suspension forward to fit the box
