Air Ride Suspensions \  Watts link questions
Air Ride Suspensions Q & A
views 445
replies 14
following 9
03on22s   +1y
At what heighth do I need to put my truck at before mounting up the link? Do I set it up at ride heighth I'm guessing?
slammeddime   +1y
To get the most possible use, you'll want to set the truck up to half of its usable lift height, and mount the watts link so that the links are parallel to the ground and each other. I haven't investigated watts links too much, so I'm not sure what the characteristics of them are regarding rear suspenions, but I would suspect that in our application, it would be almost a moot point.
redranger92   +1y
set your ride height and then mount the link with both bars parallel with the ground. Tack it and lift/drop it to see if you get the lift/drop you want. My bars were adjustable.
vinnysmini   +1y
My watt's link is setup at ride height.
BioMax   +1y
HALF TRAVEL!!! HALF TRAVEL!!! HALF TRAVEL!!! HALF TRAVEL!!!
You should set up everything at HALF TRAVEL!!!
Not ride heidth, you guys are minitruckers ride heidth is about 1.5" from the ground, not the best place to set up a suspension.
redranger92   +1y
half travel = ride height for me
03on22s   +1y
Cool. Half travel it is! Thanks guys for your input.
TRUKBLDR   +1y
hey DA why didnt you ask me bro that hurts man but your still my beotch
layedexpo22s   +1y
Hey Im running into a problem, and I think I need to fix it with the watts link. Dose anybody know where to get a good cheap setup?
redranger92   +1y
The cheapest is to make your own. Not too complicated to make. I got mine from BYC! :rolleyes:
