tacoma uniball bolt size?
mellowd@dragginminis.com's avatar
GFreeman's avatar
GFreeman
what size bolts are you guys using and what did you drill the upper mount out to... 5/8 3/4????
GFreeman's avatar
GFreeman
also how much would a place charge to drill out the hub... or what ever the hell its called? i dont have a drill press or any bits that size.
sadisticiron's avatar
sadisticiron
3/4 bolt hardened and a nylock. just go to home depot and pick up a 3/4 drill bit w/ a 1/2 inch shank
BioMax's avatar
BioMax
For an upper ball-joint/uni-ball???
If done properly you can easily get away with 1/2" bolt in a 3/4" uni-ball.
You do realize that uni-balls won't give you any more travel. In fact they will reduce your total travel by about 1 1/2"
BioMax's avatar
BioMax
Sorry Bobby, I'm not trying to hate
sadisticiron
hey no prob i dont have the time to make them so... its on you to make um im telling everybody
BioMax's avatar
BioMax
I'm thinkin' that it would help out shops like you more then it will the do-it-yourselfer. No more alignment issues, no custom arms, just a basic bag job. Plus the verticle uni-ball will allow way more suspension travel.
sadisticiron
hell yeah just like prerunner spindles. steerings is slightly limited but whos tryin to do a donut on a oneway street. the do it yourselfer doesnt relize how much work goes into one off parts either
sadisticiron
and tell steve to work harder he had way to much energy at sema
BioMax's avatar
BioMax
exactly.
