Help: my cylinders are leakin
BaggedTeg
What's up dude I haven't had any problems with my setup and I've had it about 5 months but all of sudden it gets cold outside and only when its cold my driver side cylinder leaks horribly bas like I can watch it leak but its usaully on my way to work in the mornings when its cold so I donr have time to see what's wrong but when I get off its warmer and not doing it anymore...... please help me
Thanks alot
cookiemonster13's avatar
cookiemonster13
the o ring is going bad. it is expanding and contracting
BaggedTeg
That's what I was kinda thinkin but I wasn't sure that could be it, hopefully ill get a chance to check it out thourghly today, but thanx for ur imput.......
Any other ideas....
tukn18saccord's avatar
tukn18saccord
my air cylinders do the same thing, and mine are new, it is just the o rings the best thing to do is try to keep them warm at night if not just make sure you keep the front raised
BaggedTeg
Do yall think oiling them will make the problem better or should I just order new ones......
smctoy's avatar
smctoy
I was having that problem too...when it was cold my rear cylinders wanted to leak down. I took mine apart...cleaned them with wd40 & put them back together & havent had anymore problems. Sometimes all they need to be is cleaned of the dirt/trash...it can cause the seals to leak.
Lucky's avatar
Lucky
shit mine leaks air into the cylinders......I lay mine out every night and the fucker is all the way up next day
9
92slammer
Originally posted by LuckyCharms
shit mine leaks air into the cylinders......I lay mine out every night and the fucker is all the way up next daylol.....haha what the fuck
blazins10's avatar
blazins10
spray white lithum grease in them it lubes the rings and it doesnt dry like wd 40
thatsmydawg's avatar
thatsmydawg
i had a problem with my cylinders commin appart there 3 piece and they would loosen and i had to pull over jack it up and tighten them but i had to take the whople set up out on the side and tighten it with the strap wrenches it tok 2 mins to take out 2 mins to get back in and im on the road again.
