will this work?
will this work?
twankydeuce
Can I put rims on my 2001 sierra that are made for a 2007 tahoe? i know they are the same bolt pattern, but what about the hubcentric deal?
fatheadjames's avatar
fatheadjames
You can do anything you want jeff cause your special. Really I don't see why it wouldn't work.
jsondrops's avatar
jsondrops
i got 17 avalanche wheels on my 99 yukon,bolted right on
jsondrops's avatar
jsondrops
i mean 07 avalanche
twankydeuce
shut up fathead lol.
ok cool! so I guess aftermarket rims for an 07 tahoe will bolt on to my 01 no problem.
Jance Customs's avatar
Jance Customs
I like your signature photo! If it's the same bolt pattern I don't see why they wouldn't work
I know you can put the new Dodge Ram 20's on the 94-01 Rams but I think there was something extra you need to buy to make those work, I read about it in SportTruck I think?
pat2low
THE BOLT PATTERN IS THE SAME BUT I THINK THE OFFSET IS DIFFERENT BUT NOT SURE
cookiemonster13's avatar
cookiemonster13
differnt offset is all that is differnt. if i remember correctly they will not tuck
twankydeuce
the offset is greater on the 07 tahoe wheels which makes them tuckable. The ones for the tahoe have +35mm and the ones for the nbs have +15mm...on the rims I'm looking at.
twankydeuce
ok so I called tirerack today to see if they would work and the guy said they have 100mm center bore compared to my trucks 78mm center bore. I guess this means I have to run hubcentric rings. I've never done this kinda thing before and dont know much about it. will that be ok??
