i beam front suspention
thetoymaker
i have a 79 ford and was wondering if there is any one that has bagged one or ever bagged any thing with i beam suspention if so please leave me some tips bout doing that
drptndrgn's avatar
drptndrgn
search the forums and profiles... theres a few things out there about i beams
BioMax's avatar
BioMax
The issue with I-beam front ends is that the alignment SUCKS! You can tollerate it, but if you plan on driving it daily, I would think seriously about an A-arm front clip.
Please don't post a bunch of crap about how my friend or substitute teacher or the guy that installed my garage door opener has a bagged I-beam truck and it works great.
The I-beam front ends were an easy way to build a "burly" front suspension. Ford had enough issues with them early on that some of them came with dual shocks from the factory.
If you still want to bag it let me know and I will help keep you out of too much trouble.
...Sorry
gravity5's avatar
gravity5
I have a bagged mazda with the I ebams and it works great, my teachers secretary did it for me after they installed my garage door opener as a matter of fact...LOL
Hey max you never sent me the rest of the info on the spindles....LOL I know your busy though...And yes I agree I beams are horrible for not only camber, but bump steer and tire wear...not to metnion bagging them kills the bushings in the radius arms and I beams super quick....Swap it out for an A arm setup and it will be worth it in the end.
BioMax's avatar
BioMax
I'm SORRY! After SEMA I had to re-boot. I'll get them to you this weekend, I promise.
opie90
heres my ranger setup about halfway through
NOTE: gussets should be in between the 2x2 radius arm and the bracket that gets bolted to the I Beam that photo was taken prior to me setting the angle of the I beam
bodydropped85's avatar
bodydropped85
jamey jordans truck has 3 in drop beams modifed for 5 in of drop(raised teh spinle mount up more) but he said it took him like 3 times to get it right. problem w/ those trucks is the tie rods are aon the BACK side of the ibeam.
balcar's avatar
balcar
There is a ranger that is done here http://www.lowdowncustom.com/ldc.html and it works pretty well, about as well as you can get it with I-beams. I'm doing a F150 now and putting in a front chevy 1500 front frame clip under it, its deffinatly the way to go. Just depends on what your ultimate goal of the truck. Daily driving, definatly switch out the front unless u got big balla money for tires all the time. haha
DRAGGINBODYON22S's avatar
DRAGGINBODYON22S
i have the i beams in my explorer and they work fine
cold_carcass
If you want to lay it out and not have so much camber with the ibeams got to ditch it and go with a new clip. If it's a mild drop you should be able to work with them.
