tailgate skin question
slamedb22
Edited: 11/19/2006 2:13:04 PM by dubrocker04
bout too do my tailgate skin...but i dont wanna use bondo...what is strong for smoothin out over welds before layin down the evercoat filler????
bodydropped85's avatar
bodydropped85
evercoat fiberglass filler dont forget to seal the welds on the inside of the bed to or it will rust out from the insdie out.
slamedb22
wuts a good metal filler???
bodydropped85
evercoat. besides lead there isnt an all "metal" filler
W
WeightLimit
If you dont want to use a filler or lead. Grind your weld like normal, and use a body file. The only problem with that is you need to have a pretty good bead. Or you'll still have to use a filler.
slamedb22
where can i get lead at??...and hard is it to apply?
bodydropped85
dude use filler. its not gona hurt anything. obvisouly youve never done body work and sheet metal these days is to THIN for lead work also you gota know exactly how to do the metal for lead to even stick.
jonesn
i agree a little filler is ok. not more than a 1/4 inch or so thick. or there is a product called allmetal, its like bondo but has metal not plastic in the resin. on the downside it cost almost twice as much
jonesn
W
WeightLimit
Ive used it plenty of times before, and to shave my 3rd brake light. So no it's not to thin.
But it's definitely cheaper to just use some type of fiberglass reinforced filler for the job.
