need bigger relay
cmsewell1@verizon.net's avatar
need bigger relay
22dragn's avatar
22dragn
my air zenith compressor burned up my 80amp stinger relay, so is there a higher amp relay out there? i'm runing 2ga wire with a 100 amp inline fuse to my 80amp relay with 4ga to the compressor.i need to find one before i get my recalled compressor back.
kaoss's avatar
kaoss
your truck is bad ass. We picked up a 100amp at a local car audio shop, we had to call everyone in town though.
Low_SST's avatar
Low_SST
go to a place that sells hydraulic parts for big trucks and get a continous duty solenoid they are usually 100A and diesel as disco.
slammeddime
I would wait till you get your compressor back and stick with the 80 amp relay. If it burned it up, its either a wiring issue, or a compressor motor issue... and with the AZ track record, I'd go for the later, since you have your ground covered with the former anyway.
whynotfab's avatar
whynotfab
I used a 150 amp continuous duty solenoid for my old AZ.. never any problems. the 80 amp stinger should be perfect though, but either way if you need one of those.. or want to try a 150, or 200 amp hit me up. I'd be glad to help you out.
tukn18saccord's avatar
tukn18saccord
thats the thing you need
dirkbelt's avatar
dirkbelt
damn thats crazy,i thought them comps wereonly a 35 amp draw????sounds like a wiring problem or something else
laidout94toy's avatar
laidout94toy
I had already burned up 4 relays with the AZ.
You can wire up 2 of the smaller relays for the one compressor.
tukn18saccord
im only runnin 2 30amp for my 2 vair 380s no problem
I
IIIxtremeIII
I saw a 200amp stinger relay on gravity werx website. Hope that helps.
s10
last post by baha +1y
