toyota a arms
toyota a arms
U
urdaddy
what have you guys done on you tocos to fix the camber...a arms? raise the mounts? shorten the lowers?....just looking for options
BioMax's avatar
BioMax
anything you do to the arms fix the camber when it's low will cause positive camber issues when it's lifted. That is why I am going to build dropped spindles. See the Tacoma dropped spindles thread
U
urdaddy
you are talking about 99 to 02 or 03 style spindles?
BioMax's avatar
BioMax
99 to 02 for now. I need to look at the 03 and up. Isn't 95 1/2 to 98 the same?
U
urdaddy
i think 95 to 99 is the same ...not sure about the 00 to when ever thewy changed to the mid size ....but what are ya thinking about as far as price/...ill be all about it when i get the toco off the lift....
hokieyota
z the frame?!
U
urdaddy
ya thought of that to
BioMax's avatar
BioMax
I always "z" the frame, but only untill the crossmember is level with the frame. Tacomas already have a problem with dropping the engine, why would you raise the motor more then you have to? If you could buy a set of spindles for around $600 and cure most of the issues, why wouldn't you? Do you like buying tires or maybe you like trying to figure out how to make shit just work?
I mean no disrespect, but making things work RIGHT is my biggest concern. Not what gets us by.
hokieyota
hey i agree max, i was just throwing out ideas
