BioMax
No. Unfortunately I don't.
The way the front end gets set up is the lower bag mount is welded directly to the lower arm and the upper mount ends up on the sub frame. The sub frame is heavy enough guage material to support the weight of the car, but there isn't enough area to build sufficient gussets. So, what you do is make another upper mount that that gets braced up to the factory strut mount. Don't weld these together, the moment you do the engine will blow and yo will have to cut the mounts apart to get the sub frame out. You can build the upper shock mount on the upper brace. It works out really well.
