Toyo Frame Question...
turboh22aakkord
ok... im driving a 93 2x4 this winter and im debating bagging/bd it... however my question is... is there that big of a difference between the 2 and 4 wheel drive frames? i live in maine and there are so many more 4wheel drive yotas up here... if i bought a 4wheel drive truck just for the frame would it be very difficult to fab to work with a 2 wheel drive? i also have a hardbody as well and i was wondering the same about that... thanks guys...
time1's avatar
time1
The 4wd frame and 2wd frame are different.
turboh22aakkord
thanks for the reply... i pritty much knew that they probably were different.. however is the front portion of the frame relativly the same? i mean most of these yotas all come with the 22r/re and have the ifs in the front is it even close?
TwistedMinis's avatar
TwistedMinis
Actually, someone on Pirate found out that the frame rails are the same. Just different suspension welded on it. You would have ot get 2WD front suspension still, or build your own, or go Mustang II. So not really worth it.
turboh22aakkord
thanks seth... thats kinda what i figured... and heres the thing, i already have my daily 2wd and i just wanted to buy the other frame and then use everthing off my 2wd that i have now to put on the modded frame... would that work? how much would be involved if i already had all the 2wd suspension sutff... would the cab/bed from teh 2wd fit on?
Severed701's avatar
Severed701
im confused but if i read right you want to buy another frame to work on while your driving the truck and then swap the body over when ur done??
streetsweeper1
Originally posted by turboh22aakkord
thanks seth... thats kinda what i figured... and heres the thing, i already have my daily 2wd and i just wanted to buy the other frame and then use everthing off my 2wd that i have now to put on the modded frame... would that work? how much would be involved if i already had all the 2wd suspension sutff... would the cab/bed from teh 2wd fit on?The cab and bed will fit yes. If you wanted to convert the 4wd to a 2wd front suspension components you would need to cut out the 4wd sub-frame piece that holds the control arms the suspension obviously mounts at a lower point in relation to the frame. You can cut it all out to make way for the 2wd control arm mount and lower control arm cross-member. I recommend building a custom sub-frame and ditching the stock control arm strut-trod bullshit altogether and put some custom tube arms in their place
turboh22aakkord
exactly....
turboh22aakkord
yeah man thats what i was thinking about doing i just didnt know if the cab/body mounts were the same or close...
