Wheel Questions \  Ranger offset question
Wheel Questions Q & A
views 135
replies 4
bodydragginranger   +1y
Edited: 11/29/2006 1:21:54 PM by bodydragginranger
Im currently running a 17x7 with a +12mm offset that I had built by Centerline and the clearance was great. Im switching to a 18/19 combo. Im sure the front will clear but will a 19x8 with a +20mm offset clear the lip of the fender in the rear? BTW I'm bd'ed and running a 245/35/19. Thanks
BAGD RANGER   +1y
IM NOT SURE ABOUT OFFSETS -- BUT I DO LUV RANGERS ---- --- CRIMEPAYSVIDEO.COM ---- WHAT UP BROTHER !!!
Yeah I've got a thing for Rangers too! BTW truck looks good!
bagdb2200   +1y
Those wheels will stick out just under 5mm more than your 17's did, which is just under 3/16". If you had that much extra clearance with the 17's than they will fit, just be a little closer fit.
well i had a little less than 1/4", so i guess i may have to trim the lip just a bit. Thanks
