Air Ride Suspensions \  airline routing
airline routing
Air Ride Suspensions Q & A
views 126
replies 5
following 5
02ramon22s   +1y
? for you guys, were do you perfer to run your air line? Through you cab, or under the cab along the frame rails?
bodydropped85   +1y
along the frame rail, as far away from the ground as possible.
IDROPEM   +1y
Ran em through the frame on the hardbody.
bodydropped85   +1y
i dont run em through the frame due to it could get hot from railing nad melt it.
stinkypinky   +1y
you can do both. If you run them under the carpet though only run one line for supply then T it off to the valves in the front
IDROPEM   +1y
I never had that problem, maybe I was just lucky
