Air Ride Suspensions \  stock control arms, camber? help!
Air Ride Suspensions Q & A
views 78
replies 2
caddydragn   +1y
hey, does anyone know! if i loosen up my STOCK control arms i would be able to camber in? and is it safe? i've heard it before on ssm, but just wanna get a response from anyone, any info would help, thanks....
stockflooredsdime   +1y
Your upper control arm will dictate your camber. The most you can usually do on stock control arms is move/shim them forward or backward. Whatever you do, make sure you tighten everything back up before driving.
BioMax   +1y
I'm assuming that you are talking about leaving the a-arm loose, in order to get camber. If Jake and I are right...
DON'T DO IT!
If you knew the issues that even a slightly loose bolt would cause, this question would never had been asked. Take no offense to this, just don't try it, trust us.
