Rodeo conversion
dragn92nznsi@aim.com's avatar
Rodeo conversion
dragn92nznsi's avatar
dragn92nznsi
what do i have to do to convert my headlights to rodeo? what kind of wiring is involved?
mmrcustoms's avatar
mmrcustoms
go to the junk yard and get rodeo wiring pigtails just cut them out then connect the wires but i dont know which one i have to look at my truck i will get back this afternoon
mytruckislower2
Change the pigtails. I know my 92 and 1 of my 93's came with the bolt holes already in the core support for the rodeo lights. Had to drill the other 93.
TwistedPhil's avatar
TwistedPhil
The H4 plug your truck came with has three wires- a ground, a low beam positive, and a high beam positive. The plug for the Rodeo headlights has the same three wires, so you'll just need to adapt them. You can even just use male spade terminals to stick into the old headlight plug if you want- just make sure they're secure and insulated (wrap the plug in electrical tape).
The headlights will bolt right onto 99% of the p'up core supports out there, and the grille is a direct swap. Fenders, hood, corner lights, and bumper assemblies are the same from truck to Rodeo, so you're set from there!
-Phil at FBI
dragn92nznsi
Originally posted by framelayer521
The H4 plug your truck came with has three wires- a ground, a low beam positive, and a high beam positive. The plug for the Rodeo headlights has the same three wires, so you'll just need to adapt them. You can even just use male spade terminals to stick into the old headlight plug if you want- just make sure they're secure and insulated (wrap the plug in electrical tape).The headlights will bolt right onto 99% of the p'up core supports out there, and the grille is a direct swap. Fenders, hood, corner lights, and bumper assemblies are the same from truck to Rodeo, so you're set from there!
-Phil at FBI
yeah i knew all that, the wiring is what i was wondering about... im gonna use an older rodeo (91-92) grille, i dont like the dip in the 93-95
lowromigo's avatar
lowromigo
I bought new pig tails at the parts store off the shelf for mine.
lowromigo's avatar
lowromigo
As far as the grille and head lights mine all bolted to the core support, real east conversion, to at the most 30 minutes to do to my 1994 isuzu.
Related Discussions in Isuzu
