toyota rearend
lworider1@aol.com's avatar
toyota rearend
draggnmazda's avatar
draggnmazda
i never tried the toyota conversion to a mazda yet and i was wondering if the 93 yota rear will work for me to tuck 20s i am body droped 3 inches i asked the junkyard to measure from back of drums and they said it was 51and 1/2 inces and i thinh the mazda is 52 i just want to make sure it will work planning on getting it on saturday any help would be great thanks
ShavedMazda's avatar
ShavedMazda
There are many posts on this topic if you look around, but yes the toyota rearend will work great on your mazda. It is really nice because you will be able to choose from a much bigger assortment of rims that will tuck and you will be limited to the rims you can tuck with the 6 lug pattern because of the off set. If I could find a decent toyota rearend around here I would deffinately buy it if the price was right!
tacolayingbody
Toyota rear ends are more narrow than mazda by quite a bit, U might need to narrow your frame depending on the wheels you plan on running. The mazda I am doing right now I narrowed the rear feame 4 inches overall. As for the front make plates for the upper and lower arms, trim out where needed and weld them to the mazda arms and you r done, just make sure you get them square in the arms. As for the tie rod you will have to cut and weld the mazda female side to the toyata tie rod( fter you cut them both down. I got the mazda front done in about 4 hours or so, not to hard. They also make 2" drop spindles for toyota's.
draggnmazda
thanks for the help guys yea i tried calling alot of places for 20s for the 6 bold and they all said they didnt have anything more than a pluss 34 to tuck for the 6 lug so i thought i would get the yota stuff and i talked to steve from cando and they are getting back to the tubular mazda to yota spindal next week be about a month before they ship he says and he has the drop spindals
tacolayingbody
I am building a mazda with toyota suspension and with a 20x8 +43 offset they just barley clear the fenders. A 34 offset probably will rub unless you narrow the front arms, then u will limit your lift.
