Ford Trucks \  FOGGED UP HEADLIGHT
FOGGED UP HEADLIGHT
Ford Trucks Make Specific
views 145
replies 8
following 8
Sittinlowondubz   +1y
IS THEIR A WAY YOU CAN CLEAR A FOGGED UP HEADLIGHT?? ANY HELP WOULD BE APPRECIATED
thebagshack (devon)   +1y
Buffer and Meguires Plastic Polish....
tacolayingbody   +1y
Is it foggy on the inside or on the outside? If it is on the inside let it dry out and re silicon it up air tight. Some times you have to take the lens off the assembly to clean it out.
fatboysS1O   +1y
just dont drive a ford!
Sittinlowondubz   +1y
HOW DO I TAKE APART THE HEADLIGHT WITH OUT SCREWING IT UP? I ALREADY TOOK OFF THE CLIPS BUT ITS STILL STUCK.
TwistedMinis   +1y
Usually you can heat the headlight up, sometimes in the oven if you do it right, and you can seperate it. They're just glued together. Theres a tutorial on this site in the How-To section above.
olskoolpup   +1y
a heat gun works as well. just gotta be careful so you dont end up with a pile of melted plastic
moneyhungry   +1y
all i did with mine was drill 4 holes in the light. this way air can get in there and dry it out. the holes were very small and you couldn't notice them. it cleared mine up. then i cleaned it out with windex. try that. its a cheap fix that works.
bodydropped85   +1y
wetsand w/ 3000 grit and polish.
