wheel help for fullsize!!!!! ????
weezer_411@hotmail.com's avatar
purplekush's avatar
purplekush
they came off a s10 and i wann know if theres a billet adapter to make em fit on a fullsize.. im not too sure but i cant find one online.. i know someone here would know.. help me out please!
simple-pleasurez's avatar
simple-pleasurez
unless they are differnt lug (6 instead of 5) they should fit...
purplekush's avatar
purplekush
its a 97 fullsize.. im pretty sure its still the 5 lug.. im not sure i havent tried to put them on.
droppedasachild16's avatar
droppedasachild16
if they are off an s-10 bolt pattern is different, fullsize 5x5 and s-10 5x4.5 i think
IMLOWER's avatar
IMLOWER
you can get adapters from most actual rim shops but most likely itll make the rims stick out so you probably wont want them on your truck
Mothergoose's avatar
Mothergoose
if its a 88-98 fullsize 2wd it is 5 lug unless its 3/4 tonne, but the bad thing is if you use an adaptor chances of it laying on these wheels is not very good considering most wheel adaptors are usually 1 and 1/4" thick, so you'd need a pretty crazy offset wheel to tuck and they don't usually make em on a rear wheel drive bolt pattern.
9
99lowgmc
take the wheels of the s-10 to a machine shop and make two of the wheel lug bigger and it should fit.
dante81_98's avatar
dante81_98
Why don't you just buy some wheels that actually fit the truck.
Better to do it right the first time than to have to do it again.
Later
Chad
Thebutchershop's avatar
Thebutchershop
i dont understand that comment? would you mind explaining it for me? maybe i jus didnt read it rite
prorida's avatar
prorida
very true, those won't work. sell them for some 5x5, and remember caprice's are the same as fullsize, (if your looking for used wheels). or lame industries will make you a set of adapters, but they probley won't lay.
