should I remove my powering steering?
1987bseiresman avatar
1987bseiresman
Should I remove my powering steering for a tighter feel or get a bigger swaybar and bushings. It' a 2wd truck too.
DOWNSUB avatar
DOWNSUB
why would you remove your P/S ? If your front end is loose sound like you need new bushings.
DougyFrisch avatar
DougyFrisch
if it's not due to motor, suspension, or wheel clearence then leave that shit. don't do it for "better handling"
BioMax avatar
BioMax
If you loose the P/S make sure you run a non power box. If you occasionally take your truck to the track or are a total corner junkie, there may be a small prefernce to manual steering. Power steering "mutes" the steering input from the road, something that ture driving connoisseurs prefer. A larger Sway bar will not offer the same effects that the manual steering does.
white93yota- It looks to me like you need to do some serious homework on the subject. Buy the book that I posted on your other thread and see what it really takes to make a vehicle handle. Then if you still have any questions, post again and we'll address them.
mitsu94 avatar
mitsu94
hell no i dont have power steering on my max and it sucks
BioMax avatar
BioMax
If your non power steering sucks, there is something amiss. Scrub radius is a major cause of tough steering as well as too much castor. I know from expierence that the Toyota's don't take very much steering effort with out power assist. I'm not sure about the Mitsu's tho.
mitsu94 avatar
mitsu94
it aint as bad as if u had power steering then ur pump went out or something but it is almost impossible 2 manuver through parking lots using 1 hand 2 steer. if i had a choice it would be power.
