Replacing stock radio/bose question.
dstanford5@gmail.com's avatar
ngacleetus's avatar
ngacleetus
I have an 04 GMC Yukon with Bose. Is there any problems replacing the factory unit and installing aftermarket? I got the wiring harness. I had heard there might be problems because of the amp with the bose system. Anything I need to be aware of?
justin skaggs's avatar
justin skaggs
Edited: 12/10/2006 12:24:14 PM by justin skaggs
As long as you got the right harness you should be fine. Just make sure you hook the amp turn on lead up!
fatheadjames's avatar
fatheadjames
IF you have just a $20 harness you probably have the wrong one. THe harness you need is about 50-75 I think. It allows you to keep the door chime and intergrates your amp.
9
92fordranger
hit me up on aim or e mail me ill tell u how to do it
ngacleetus's avatar
ngacleetus
i got the $20 harness. I haven't heard anything about the other harness. i just don't want to degrade the integrity of the system.
W
Wakeboard03S10
Edited: 12/10/2006 4:03:54 PM by Wakeboard03S10
you will be fine on the $20 harness its just some scam that places try and sell you one with the door chime and all that shit. Only problem you might run into is onstar if you have that. you have to either wire around it or get the expensive harness but if you wire around it, it wolt work.
ngacleetus's avatar
ngacleetus
I don't have onstar/xm/gps or any of that. i wish i did and i wouldn't need to replace anything.
fatheadjames
It's not a scam if you remove the radio you lose the door chime unless you relocate the radio or use an adapter with it built in.
mobileheath's avatar
mobileheath
"my dad has bose....what your dads stereo blows???" lol sorry I couldnt resist
W
Wakeboard03S10
to me 50-75 bucks for a door chime when your headunit will work with a $20 harness is a scam. but thats just me.
