Has anyone made edc brackets for a toyota. If so how hard was it and did you just buy in s10 one or what?
floorrunner
i used a york 210r compressor, my truck didn't have p/s on it so i bought the bottom third pulley that is bolt (goes on the crank shaft) then i bought the p/s pump bracket and tensioner. used two small pieces of angle iron and mounted it to the p/s bracket and to a piece of flat iron to the compressor, remember when you use a york compressor install a oil trap so you don't get oil in your system.
