how to flip balljoints
X
1989dangeroustoy
how do i flip the ball joints on bagged suspension,on an 89 toy
smctoy's avatar
smctoy
Ok...if your suspension is like mine & it should be then all you have to do is unbolt the ball joints for the bottom of the upper & lower control arms, place them on top of the arms & bolt them back down. It took me about an hour or so do both sides with simple tools. If you want I can take a pic tomorrow of it & post it for you...if not hope this helps!!
1989dangeroustoy
yea the only thing is that,the bottom control arm has the support bars the hook up to the frame,so there are two mounting bolts the look like they would be in the way, thanx for the reply
1989dangeroustoy
any one have any pics?
SD
Some Drunk Guy
If your gonna flip them I would recomend going with an aftermarket ball joint. Ones that have more degrees and are stronger. I personally only flipped the upper ones and gained about 1 inch of extra travel...
