can anyone help with my idle prob
2be1off avatar
2be1off
--------------------------------------------------------------------------------i have an 89 exCab yota it has a 4 cylinder fuel injected when im at a complete stop the RPM`s go from 1g to 2g really fast up and down. but when i push on the brakes the RPM`s go from 1000 to 1300. ive already replaced (alternator, battery, pcv) i checked the vacuum that comes off the brake booster. can anyne help
Some Drunk Guy avatar
Some Drunk Guy
Dood irradic idles are usually vaccum related, Im saying usually....cause sometime could be a little more serious like compression or timing related, or intake manifold leak...but most likely u have a crack in a vaccum line somewhere....check them all.....
truck action avatar
truck action
If fuel injected, there are about 4 sensers that can cause this. Also if bad thermostat, won't come off cold start, causes that!!
oneup avatar
oneup
Vacuum leak would be the first thing I would check then I would go for the throttle position sensor.
2lowtoy avatar
2lowtoy
I second that one I have had the same problem. Make sure the plug in tight on the tps to
time1 avatar
time1
toyotas
