dssur
just trim the part that goes around the frame, you can see where it is hitting, it leaves a mark on the lower.
You need to make sure your strut rods dont hit the tie rod though, you can get a lot more drop than the strut rod/tie rod will let you go down, so a lot of guys notch it before they bodydrop it, then they body drop the truck and lower the whole front crossmember which lowers the strut rods and bang. Hits the tie rods. Insta screwed. I recommend just dropping the ears of the crossmember, which alleviates this problem.
I dont think only needing 3/4 you will have a problem though.
