Ford Trucks \  89 Ranger Body Drop
89 Ranger Body Drop
Ford Trucks Make Specific
views 103
replies 6
SMALLBLOCKDRAGGER   +1y
Having probs clearing 20s with toyo front suspesion any shops in lower Michigan?
Gump1986   +1y
are the radius rods on the lower control arm binding? if not that, check and see if the balljoints on the upper arm are binding. the yota balljoints that I had in my first set of upper arms would bind out at full lift, before untucking a 20.
bodydropped85   +1y
what bag are u running? how close is it mounted to the pivot point?
Slam Specialites bag mounted on toyo front end.
TwistedMinis   +1y
How much lift are you getting? How much do you need? I'm getting an easy 12" of lift with 100 PSI and about 14" of useable travel out of the balljoints. I have RE7s up front.
bodydropped85   +1y
also how high did you mount the clip?
I think I found prob front cross members below motor too high? Thanks for the info, any suggestions on a good compressor?
