lower control arm/ torsion bag question
dan48p avatar
dan48p
ok, clipped my ranger with a toyota frame in the front.
now i'm getting to the bagging process.
my question is, do you have to take anything out of the lower control arm pivot point on the frame or do you just leave it all stock?
with no weight on the truck the spindle wants to go back down when you pull it up (not from the weight, but like there is tension forcing it down)
do you guys just leave it like that or replace it with a bolt or what?
TwistedMinis avatar
TwistedMinis
Thats the bushing wanting to pull it back down. When I put new bushings in I could pull the suspension up and it would stay there if the spindle wasnt in place.
tbmx86 avatar
tbmx86
Im having that same problem on my ranger too. Where can you get new bushings for the yota clip?
scotto79 avatar
scotto79
any autoparts shop should be able to get them, just make sure you order for that year Toyota. They are just a stock part and would only need a stock replacement.
TwistedMinis avatar
TwistedMinis
Energy suspension makes everything for them just about. Summit carries them.
dan48p avatar
dan48p
cool, thanks guys
dan48p avatar
dan48p
found them, 32.99 from summit. is that a good price?
TwistedMinis avatar
TwistedMinis
Thats what I paid for mine. Factory rubbers are more expensive.
