Yet Another Problem
justdrgnby@hotmail.com's avatar
Yet Another Problem
sparkranger's avatar
sparkranger
I bumped the previous thread with this question but no one saw it.
I fixed my power issue. Ended up being the fuseable link. I am now, not getting spark.
We hooked up a timing light during cranking and saw nothing until the key was turned off. Same thing with the screw driver/Plug wire test.
Help me...
sirbodydragger's avatar
sirbodydragger
did you check ALL of the grounds ?
laydsuzu's avatar
laydsuzu
Yeah, check ALL of your grounds
sparkranger
Yes...several times. Pulled off the ones I moved and cleaned both the ground, and the spot it was being grounded to.
Now, I'm not 100% sure if "clean" paint would affect it or not (I cleaned some serious dirt off of where the coil sat).
What specific grounds should I be checking?
sparkranger
Bump
