STOCK 4 LINK
STOCK 4 LINK
b20vtecpt
HAS ANYONE HAD ANY PROBLEMS WITH THE STOCK 4 LINK ON NAVIS OR EXPEDITIONS BINDING AND THE REAR AXLE MOVING ABOUT AN INCH????? NEED AN ANSWER PANHARD OR TRIANGLE OR WHAT ELSE DO THE HAVE
bodydropped85's avatar
bodydropped85
they have a panhard bar.
b20vtecpt
who makes the panhard???? bolt up or weld??? is it going to be strong enough to hold the rear end after mounted or should i do a new 4 link. what makes the axle shift
pimptruckman92's avatar
pimptruckman92
i think its just the travel of the panhard on the suspension that causes it to move laterally i read that at full lift a panhard will pull the axle to one side. look into a watts link they keep it centerd throughout travel and i've seen a factory watts link on a land rover SE7 i think it was
TwistedMinis's avatar
TwistedMinis
Yeah the Expos have a forward 4 link. The uppers are semi triangulated. It has a panhard that is just formed steel. The stock one could be braced and be plenty strong. The stock one will pull your axle pretty far. I made one tuck a lip on 20s with semi large tires, and the tire was really close on the driver side. And the upper 4 link bar on the passenger side hit the frame. So I notched a little piece out of the frame and plated it up.
b20vtecpt
HOW CAN I RE-ENFORCE THE STOCK 4 LINK
wht01ranger's avatar
wht01ranger
shouldn't be a need to strengthen up the stock 4link bars, you wouldn't have room to put a bag on the bars anyway. what you need to do is just make a new panhard bar so it doesn't shift the axle so much.
if you want the thing to lay out, then ditch the stock 4link for many reasons.
Psycopath's avatar
Psycopath
on my old pathfinder i made the panhard rod adjustable by welding in a tie rod, so i could adjust where it sat when down.
b20vtecpt
ANY ONE GOT A GOOD PIC TUTORIAL?
s10
last post by baha +1y
