wht01ranger
Edited: 1/4/2007 7:48:04 AM by aftershock
you guys are retards, it's obviously a broken motor mount.
but naw, check connections, mainly grounds. no way to tell if your alt is out if the truck isn't running, and with a loose connection, all the charge from the alt. isn't getting to the battery, and the battery will obviously die because of it. so check your connections if it still clicks when you are jumping it.
once you get it running, put a volt meter to your battery. should be around 14volts with just the motor running. from there, you will see if the alternator is bad.
if all your connections are good, and the voltage reading rises from not running to running, and your battery just keeps dying, then replace your battery.
