REAR END NARROWING
brianbgboy@gmail.com's avatar
REAR END NARROWING
brianbgboy's avatar
brianbgboy
who are you guys using to narrow the rear end? i am pulling mine out tommorrow, and need to have it done. thanks, bgboy
maz89
I had my friend Kelvin that runs a local hotrod shop shorten my housing. My axles where custom cut by Moser.
DK
diabolic kustoms
might be cheaper to find a stock narrower rear. I found a 42" for $150. There are a lot topics on these, use the search
jcampbell1180's avatar
jcampbell1180
Your not supposed to say that. It's in the rules. Use the search function, Dummy.
pig rig's avatar
pig rig
I think this needs to be a sticky along with tire size and bag size
hell even add one of why 52 link is better then a 2 link
dragnasty's avatar
dragnasty
dont get me started on the 2 links verses the world!!!!!!
balcar's avatar
balcar
ow ow, here we go again..
I am using a cab/chassis rear end in mine. One of these days i'll have it built. Got it off ebay for 51 bucks.
balcar's avatar
balcar
Also another thing
14 bolt full floater, u can use a single rear wheel axles and axle tube with dually hubs will build you the same rear, but you will have to carefully cut the mounting plate for the brakes and move them inward to clear the inner wheels.
pig rig's avatar
pig rig
well I think the more shit you hang from your rear the better it works. a 2 link just isn't cluttered up enough but if you bend up 600ft of a plumbers nightmare and weld it from bed side to bedside every one will be impressed that your a craftsmen and they won't question weather or not your 52 link,quad bag,triangulated parallel cantilever,monkey ball shaven setup works
brianbgboy's avatar
brianbgboy
my truck is a factory 1 ton single wheel, in which i converted to dual with front and rear adapters. i know on the front i can just run the semi adapters direct to my factory hubs, but on the rear i am narrowing the rails for clearance, but i want to go up with the fenders, not anymore out. the wheels i will be getting are standard semis, not the townastys, so, do you think it will still need narrowing? thanks for all your help, bgboy
