Help..
Help..
Alerouc
Edited: 1/4/2007 7:45:15 PM by Alerouc
ok so I have my Air Struts on, tank is in, valves are on, air hoses ran, wires ran switch box ran so when i turn on the compressors and let them run for a while they never cut off, as they are suppose to when it reaches 200 psi, checking for leaks in every fitting with soap and water, there are none. when I hit the switch alil air comes out. I hear it but i dont fell anything and if I press the switches and check for air leaks with my hand. I still feel none let me know what is going. I have viair 380 compressors.
slammeddime
Do you have a gauge on your tank so you know what the pressure is?
Alerouc
I did but I thought it was leaking from there so I took it off and tightened i tand tried it again but nothing was happening so I took it off and plugged it...
s10
last post by baha +1y
